kmgdawgs
Sep 14, 2021Aspirant
Access Points
I recently purchased a NETGEAR Nighthawk R7350 AC2400 Router: I am trying to find out which access points would work best with this router for my home.
kmgdawgs
it is a little over 5000 square feet. We have a main floor which is where the router is now. An upstairs and those see to be getting coverage from the router ok and a basement that is actually getting pretty good coverage except one room in it. I was thinking about adding an access point upstair and basement for better coverage.
Sep 14, 2021Guru - Experienced User
Not a bad choice. Any chance you can return the new router and switch to a mesh system?
That's the route I'd go for that much area and for seamless roaming.
