darkjfman
Jan 15, 2020Tutor
Accessing DLNA RAX80
I previously had R7000, due to its limitations I decided to upgrade to the RAX80. One of the issues I'm having is I'm losing access to shared storage from what seems after idle use. With the R700...
- Jan 17, 2020
Hi darkjfman,
Just curious, have you tried reverting back to the previous firmware version to see if the issue persists?
Christian
darkjfman
Jan 18, 2020Tutor
I have not reverted back. According to support they suggested flashing the router then doing a factory reset, I did all that after backing up my settings. I performed the action on Wednesday 1/15, everyday since then I was able to access it until this morning. Now when I do access it, the playback video is very rough. The audio is always there, however, the video slows down and at some point just freezes on a single screen with the audio still playing. It seems it's trying to buffer, restarting the movie does fix the issue momentarily but then it starts again.
I'll attempt to revert back one version and report back. Do I need to reset it or it would work the same by just reverting?
Christian_R
Jan 20, 2020NETGEAR Employee Retired
Hello darkjfman,
Thanks for getting back. It is not required but if you do revert to a previous version it'd be great if you could report back. I do recommend that you please continue to work with our Support Team on your issue.
Thanks,
Christian
- darkjfmanJan 20, 2020Tutor
I'll go ahead and do that. I reverted back yesterday 1/19, as I mentioned it takes a while to see if it works or not, since typically I noticed that disconnection after a long idle from the HDD. I'll report back in the next day or so and see if I'm still able to get a connection.
