darkjfman
Jan 15, 2020Tutor
Accessing DLNA RAX80
I previously had R7000, due to its limitations I decided to upgrade to the RAX80. One of the issues I'm having is I'm losing access to shared storage from what seems after idle use. With the R700...
- Jan 17, 2020
Hi darkjfman,
Just curious, have you tried reverting back to the previous firmware version to see if the issue persists?
Christian
Christian_R
Jan 17, 2020NETGEAR Employee Retired
Hi darkjfman,
Christian
darkjfman
Jan 30, 2020Tutor
Christian_R wrote:Hi darkjfman,
Christian
Reverting back to the previous firmware, 1.0.1.64, does solve the problem. I'm not sure if you're able to forward this to the Tech team, my ticket was closed and I assume they are aware that reverting solved the issue but can't know for sure. Hopefully it'll be fixed in future releases.
- Christian_RJan 31, 2020NETGEAR Employee Retired
darkjfman,
Thanks for reporting back! I'll be sure to let the team know.
Christian
