darkjfman's avatar
Jan 15, 2020
Accessing DLNA RAX80
I previously had R7000, due to its limitations I decided to upgrade to the RAX80. One of the issues I'm having is I'm losing access to shared storage from what seems after idle use.   With the R700...
  • Christian_R's avatar
    Jan 17, 2020
    Hi darkjfman,
    Just curious, have you tried reverting back to the previous firmware version to see if the issue persists?
    Christian
