sudo-visudo
Feb 28, 2022Aspirant
Accessing media from connected USB drives
I have an RAXE500 with 2 USB drives connected to each USB port. When trying to access media through my Roku player or Samsung smart TV on the same network, it shows Part1 and Part2 for each drive (li...
sudo-visudo
Mar 11, 2022Aspirant
This is for anyone with a similar issue:
I "downgraded" to firmware version 1.08.70 - PROBLEM SOLVED. I'm also noticing the router is generally faster and more stable. Version 1.09.78 is buggier than a tropical rain forest. Avoid it like the plague! I've disabled automatic updates and will wait for the next release, assuming it works like it should.
This isn't the first time Netgear releases a buggy update. I remember 1.07.xx broke the access control function. I didn't notice any other difference from the previous release.
