mjz's avatar
mjz
Apprentice
Sep 09, 2020
Accessing router login page behind another router - AX3000
I have an AX3000 (RAX35) bought new last November.
Normally I have it in AP mode, but recent firmware updates screwed up email and wi-fi radio schedule on/off. They no longer work even after factory resets, reboots and set-up.
I decided to take it out of AP mode and set it up as a full router (10.0.0.1 IP) behind my Internet provider's router. It works fine this way allowing devices connected to it to access the Internet which I don't normally need to access from my 192.168.x.x. network.
Unfortuntely, I don' tknow if there is a way to access the Rax35 login page from my 192 network? I can only access the settings pages by hardwiring a laptop I have handy to one of the LAN ports. It works, but a pain to do.
Is there a way to access the router login page so I can configure settings (i.e. wifi on/off schedule) from my desktop?
1 Reply
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hi mjz,
    Were you able to sort this out? Essentially you should be able to login your router as long as you're connected to the RAX35 network and visiting www.routerlogin.net.
    Christian
