PADWIS
Dec 12, 2019Follower
Add USB drive to RAX200
How do I add a USB drive to router
1 Reply
First make sure you get a drive that'll work with readyshare.
https://kb.netgear.com/18985/Will-my-USB-drive-work-with-ReadySHARE
this isn't all inclusive but its just a list of reported drives that have worked.
then make sure you have it in the correct format.
https://kb.netgear.com/24059/What-are-the-USB-drive-requirements-for-my-Nighthawk-router
Then read through the manual a little bit. Starts in section 8, page 120
