Jacek26
Jan 08, 2023Tutor
Adding a fan to RAX120
Can I add a fan to the rax120 router by plugging it in to the usb ports on the back and will that power the fan? I want the router to be cool I know about the internal fan and about the debug optio...
Mujiga
Jan 09, 2023Tutor
Yes, you can swap out the fan for the RAX120. The stock OEM fan that the RAX120 uses is a 50x50mm fan made by Delta. You can see the in the FCC photos, https://fccid.io/PY317300397/Internal-Photos/Internal-Photos-Part-2-3990332 the model number. The only fan that I have found that matches the OEM fan, is one made by Fractal. Hope this helps.
I should add, the page where I got the internal photos is https://fccid.io/PY317300397
You can see the that the RAX120v2 was undergoing FCC testing in Oct 2020 & the initial RAX120v2 firmware release was in Dec 2020.
- FURRYe38Jan 09, 2023Guru - Experienced User
Would be much easier to avoid any router intrusion and fan frustrations and install a laptop fan cooler under the router.
I keep one under any router I use 24/4 for additional cooling. works well:
I use this one: https://www.amazon.com/Thermaltake-Massive-Adjustable-Notebook-CL-N004-PL20BL/dp/B00IGSATZY
