GetOutDaWay
Nov 25, 2021Follower
Adding a second nighthawk RAX80 to network as AP with same SSID
I would like to buy and add a second nighthawk RAX80 and wire it into my network to funtion as an access point. I want to keep one SSID like I have now allowing cleints to hop to the strongest sig...
Nov 26, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
Thank you.
