DavJ's avatar
DavJ
Follower
Apr 19, 2021
AdGuard DNS added to an AX8 router
I recently upgraded my R6700 Nighthawk router to the new AX8. Love it.
I'm having one difficulty with it. My old router I had AdGuard DNS address added to it to block ads on all the devices on that wireless network. With the new AX8, I'm not sure where to enter the DNS figures into OR if I should be using the IPv4 or the IPv6 set.
I'm oldish, and suprised I was able to get it on the R6700, but the new AX8 is a little more sophisticated.
I could use a tech hand please.
IPv4  94.140.14.14   94.140.15.15      IPv6  2a10:50c0::ad1:ff   2a10:50c0::ad2:ff
Thanks in advance!
1 Reply
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hi DavJ,
    If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
    https://www.netgear.com/support/contact.aspx
    Christian
