cyberwasp
Oct 25, 2021Star
Adguard how to disable
Recently my Echo Show 8 has been saying it cannot connect to the internet when it's been working since I got the Nighthawk RAX50 router. I read someewhere that it might be Due to having Adguard. Wher...
Oct 25, 2021Guru - Experienced User
What modem/gateway do you have?
What firmware is on your router?
Did this recently just start? you said its been working for a while?
- cyberwaspOct 25, 2021Star
The Cable modem is a hitron E31N2V1. Router is a ATX5400 nighthawk RAX(50), "Firmware Version V1.0.2.82_2.0.50. It's ben up since I got the router, over a month ago. started maybe a week ago. Everything else connected via wifi is fine. I haven't changed anything in the router.
