cyberwasp
Oct 25, 2021Star
Adguard how to disable
Recently my Echo Show 8 has been saying it cannot connect to the internet when it's been working since I got the Nighthawk RAX50 router. I read someewhere that it might be Due to having Adguard. Wher...
cyberwasp
Oct 25, 2021Star
The Cable modem is a hitron E31N2V1. Router is a ATX5400 nighthawk RAX(50), "Firmware Version V1.0.2.82_2.0.50. It's ben up since I got the router, over a month ago. started maybe a week ago. Everything else connected via wifi is fine. I haven't changed anything in the router.
Oct 25, 2021Guru - Experienced User
have you tried updating the firmware?
- cyberwaspOct 25, 2021Star
yes. I also just reset everything, including the router. it worked for about 4 minutes then went offf line again, odd!!
OK, this is weird. I just reset the moderm via the gui and now everything has miraculously came back to life. I'm guessing the reset button and the GUI reset do completely different resets!
I think it's time to get a better brand router. it lasted 4 hours and now it's conecting/disconnecting wifi
cyberwasp wrote:OK, this is weird. I just reset the moderm via the gui and now everything has miraculously came back to life. I'm guessing the reset button and the GUI reset do completely different resets!
