clipcorner
Sep 11, 2023Tutor
Admin access locks up
After successfully setting up my router (#RAX43v2), now when I log in to the admin console via the web interface, the interface locks up when I attempt to click on Advance options (e.g. Setup or Admi...
Sep 11, 2023Guru - Experienced User
Same thing happens with MS Edge browser?
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
clipcorner
Sep 11, 2023Tutor
Thanks for the suggestions!
Same happens with Edge.
Router firmware is v1.1.3.18.
I've not yet done a new factory reset - but will try that next.
I'm using the flat cable that came with the NG router to connect it to the cable modem (from Spectrum, Hitron E31N2V1). I will swap that cable for a short, CAT 5E cable.
