clipcorner
Sep 11, 2023Tutor
Admin access locks up
After successfully setting up my router (#RAX43v2), now when I log in to the admin console via the web interface, the interface locks up when I attempt to click on Advance options (e.g. Setup or Admi...
michaelkenward
Sep 11, 2023Guru - Experienced User
clipcorner wrote:
After successfully setting up my router (#RAX43v2), now when I log in to the admin console via the web interface, the interface locks up when I attempt to click on Advance options (e.g. Setup or Administration).
The obvious first boilerplate question, if there is one it might also help if you told people the make and model number of the modem/gateway/ONT that sits between this router and the Internet. Is it, by any chance, also a router, with a set of LAN ports on the back?
I ask because a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
Having two routers on a network can cause headaches. For example, you can end up with local address problems. And that could explain what you see.
- clipcornerSep 11, 2023Tutor
The cable modem is a Hitron E31N2V1 - not a router, just a modem. I didn't think the modem would affect this issue, but I did provide the make/model info in my previous reply.
