clipcorner
Sep 11, 2023Tutor
Admin access locks up
After successfully setting up my router (#RAX43v2), now when I log in to the admin console via the web interface, the interface locks up when I attempt to click on Advance options (e.g. Setup or Admi...
Sep 11, 2023Guru - Experienced User
Same thing happens with MS Edge browser?
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
clipcorner
Sep 12, 2023Tutor
I did a factory reset. The FW was up to date already. I replaced the cable to the modem.
the biggest change was that I did NOT enable the Armor security option.
So far, the web and nighthawk apps appear to be working as expected - i.e. no lock ups.
I'll continue to monitor.
- FURRYe38Sep 12, 2023Guru - Experienced User
AT some point, try enabling Armor and let us know what happens...
