Memmaatre
Apr 26, 2023Aspirant
Admin interface not responding on RAX200
My rax200 router is sluggish. Sometimes the interface hangs. Especially, it is not possible to activate QoS - the tick is set but the speed test just stands and shows progress but never ends. When I ...
Apr 26, 2023Guru - Experienced User
what firmware version are you on?
I'd try a factory reset and reinstall. The RAX200 responded well (the one I have) to factory resets after firmware changes.
