b7-
Aug 26, 2020Follower
Advanced Port Forwarding & Static Routes - Nighthawk RAX200
After doing some research, I came to find the RAX200 to be the best ranked Wifi6 Router in the market. So, I purchased a unit yesterday, plugged it in, updated the firmware and started the configurat...
Christian_R
Sep 01, 2020NETGEAR Employee Retired
Hi b7-
Welcome to the community! If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
http://www.netgear.com/support/contact.aspx
Christian
