marchvet
Mar 20, 2022Tutor
Advanced tab grayed out
I added a static IP address to my router last night and then updated to the latest FW(V1.0.10.110_2.0.72). Afterwards, the advanced tab is grayed out and I can't access it. I have rebooted the r...
Mar 20, 2022Guru - Experienced User
did you click on it?
Because thats how it shows up unless you've actually selected it.
marchvet
Mar 20, 2022Tutor
I DL chrome and tried it and it works. Not sure why Safari stopped working after the FW update.
- michaelkenwardMar 21, 2022Guru - Experienced User
For some time now Netgear's manuals have warned that some things don't work in Safari:
"This Administration recovery process is supported in Internet Explorer, Firefox, and Chrome browsers, but not in the Safari browser."
Baffling.
- plemansMar 21, 2022Guru - Experienced User
Either way, glad you got it working!
Sucks that safari is the underlying issue.
- FURRYe38Mar 21, 2022Guru - Experienced User
What version of OSX and Safari?
Be sure to clear out all browser caches in Safari and try again.
- marchvetMar 21, 2022Tutor
Monterey 12.3, Safari 15.4. I cleared out the cache several times but still wouldnt work. Is there anything else that should be cleared as well?
