Dogain
Apr 10, 2022Aspirant
Advanced Tab not functioning on Rax15 ax1800
Hello,
I own the rax15 ax1800 router, hoping to find a solution concerning the bug linked with the latest firmware update :RAX15-V1.0.10.110_2.0.72
I checked out the community here and found out that many users were experiencing the same issue as I am, advanced tab not working due to the latest firmware update!
i tried the following :
reset the router
switched browsers
tftp command from windows (followed it to the last letter) :https://kb.netgear.com/000059633/How-do-I-upload-firmware-to-my-NETGEAR-router-using-a-TFTP-client-o...
but had no result it just doesn’t install or downgrade the firmware (form: RAX15-V1.0.10.110_2.0.72 to RAX15-V1.0.4.100_2.0.64)
Has anyone else found a way of solution around this problem?
Thank you in advance.
Best regards
- DogainAspirant
No, i didn’t. I’ll give it a shot. I wrote to DarrenM, unfortunately still haven’t received a reply…
Thanks.
- Razor512Prodigy
If the advanced tab cannot be accessed, the direct link to the firmware update page may work.
192.168.1.1/UPG_upgrade.htm
- DogainAspirant
I will try. thanks for the info 🙂
