almm
Jan 19, 2021Aspirant
Advice: looking for inputs to replace the R7000P for the RAX200
I am looking to get a new router that comes with Circle to help manage kids Internet access. I used to have the R7000P but since we migrated from Cable Internet to the Gigabit Fibe 1.5 by Bell, I not...
Jan 19, 2021Guru - Experienced User
the 150mbps you're getting, is that over wifi or wired?
What speeds do you get wired?
the R7000P should be able to hit gigabit over a wireless connection.
Try disabling access control, qos, parental controls, and traffic monitoring and doing a reboot on the R7000P
What actual firmware is on it?
have you went into the Bell device and put the netgear's ip address into its dmz? (since it doesn't have bridge mode)
- plemansJan 27, 2021Guru - Experienced User
sorry, went back over this and re-read it and i said it should hit gigabit over wireless. I meant over wired. My bad.
