TOK2000
Dec 21, 2020Aspirant
After setup of AX6600 - RAX70 I have two networks
I went through the setup using the app and got it setup and running quickly, but I ended up with 2 networks. The wireless network is on the 10.0.0.1 But my wired devices which are connected ...
- Dec 21, 2020
Access point mode is netgears version of bridge mode.
It disables the router features and leaves the att router controlling it.
Dec 21, 2020Guru - Experienced User
- TOK2000Dec 21, 2020Aspirant
What are the steps to change this to access point? I don't see it in the App.
Thanks
OK I found the routerlogin.net advanced mode and saw the AP mode and chose that and now all my devices are on the same networks, the 192.168.1.x
I see that in addition to Router Mode and AP Mode there is a Bridge Mode but it's not clear why I would choose AP Mode over Bridge Mode or vice versa.
AP Mode works for me, but what have I given up with this and would it be different in Bridge Mode?
Thanks
- plemansDec 21, 2020Guru - Experienced User
You don't want bridge mode. Bridge mode literally turns it into a wireless bridge. The one in bridge mode's wireless is only usable for the connection to the router.
- michaelkenwardDec 22, 2020Guru - Experienced User
Not really.
In this context "bridge mode" usually means "wireless bridge mode". It needs a wireless link (bridge) between the device and the router. You could also see it as "repeater mode".
Access point mode has a wired link between the device and the router.
Just about every router can work in AP mode whereas only some are capable of wireless bridge mode.
However, the bottom line is that in either mode you lose many of the router features in the second device.
- plemansDec 22, 2020Guru - Experienced User
michaelkenward yeah, didn't get into what OP was discussing until later. My bad.
Unfortunate how different manufacuters call different setups bridge vs ap vs passthrough vs etc.
for example, my Arris SBG8300 uses bridge mode to put it in modem only mode and my arris mesh system uses bridge mode for access point mode.
a little standardization would be good even within the same manufacturer.
- TOK2000Dec 22, 2020Aspirant
I'm not clear what features of the RAX70 are lost when I went to AP Mode.
