TOK2000
Dec 21, 2020Aspirant
After setup of AX6600 - RAX70 I have two networks
I went through the setup using the app and got it setup and running quickly, but I ended up with 2 networks. The wireless network is on the 10.0.0.1 But my wired devices which are connected ...
- Dec 21, 2020
Access point mode is netgears version of bridge mode.
It disables the router features and leaves the att router controlling it.
Dec 21, 2020Guru - Experienced User
TOK2000
OK I found the routerlogin.net advanced mode and saw the AP mode and chose that and now all my devices are on the same networks, the 192.168.1.x
I see that in addition to Router Mode and AP Mode there is a Bridge Mode but it's not clear why I would choose AP Mode over Bridge Mode or vice versa.
AP Mode works for me, but what have I given up with this and would it be different in Bridge Mode?
Thanks
- plemansDec 21, 2020Guru - Experienced User
You don't want bridge mode. Bridge mode literally turns it into a wireless bridge. The one in bridge mode's wireless is only usable for the connection to the router.
