Vilda
Aug 26, 2020Aspirant
After upgrade to the new firmware the router sometimes failing with a connection
RAX80 — Nighthawk AX8 8-Stream WiFi Router
I'm using firmware version V1.0.2.76_1.0.35 if I upgrade to the new firmware V1.0.3.98_1.0.46. Router not working like before. Everything on the Wifi is d...
schumaku
Aug 27, 2020Guru - Experienced User
Vilda wrote:... Everything on the Wifi is disconnected for every few moments, the network is not stable. ...
There are some stupid logs about attacking, but it is misleading (those atack are from my provider or Apple service etc):[DoS attack: ACK Scan]
Can't speak for the RAX80 connectivity issue. However, this is a nice proof that many "DoS attack" detection and log entries are false positives - caused by connectivity issues, e.g. short disconnect/reconnect, roaming to/from other non-mesh wireless access points or the mobile network, ...
- bandit00013Aug 30, 2020Aspirant
Second this. Post-upgrade to .98 I've had to reboot the router multiple times as it stops responding and providing internet access to devices. It also intermittently will not allow me to log into it even though it is serving data to devices. May roll back to the previous framework.
