aellsworth
Dec 26, 2020Aspirant
AirPlay to HomePods not working with Smart Connect
I’ve had this router for a year now. For the first four months it worked great, but the last 8 months I haven’t been able to use the Smart Connect feature. When enabled I’m unable to AirPlay my music ...
Christian_R
Dec 30, 2020NETGEAR Employee Retired
Hello aellsworth,
I would check to see if your RAX80 is due for a firmware update.
Christian
- aellsworthDec 30, 2020AspirantHi Christian,
Thanks for the suggestion, but I check and apply updates every week.- Christian_RDec 31, 2020NETGEAR Employee Retired
Hello aellsworth,
May you provide me wit the current firmware version number your router is on.
Thanks,
Christian
- aellsworthJan 01, 2021AspirantV1.0.3.106_1.0.50
