TravelerTD
Jul 19, 2020Aspirant
Airtime Fairness R8000
I need instructions on how to disable the airtime fairness. I have logged into my Netgear router X6 R8000 and looked everywhere. I cannot find where to disable it. I am using my laptop to log into my...
TravelerTD
Jul 20, 2020Aspirant
The security camera and bulb company said it would be best to turn it off.
Tracy
Jul 20, 2020Guru - Experienced User
Why are they saying that?
Actual going over what issues you're having can help us to help you.
- TravelerTDJul 20, 2020Aspirant
I tried to follow the instructions they sent but my router interface looks totally different than what they sent.
- plemansJul 20, 2020Guru - Experienced User
Again, why do you think you need airtime fairness disabled. it shouldn't stop setup.
What issues with those devices are you having? We aren't there to see whats going on so a better description helps.
Sorry, I tried posting this but it doesn't seem to have stuck. Wyze had me use an app called RouteThisHelps. After I sent the code to Wyze, they sent the following suggestions.
Hello Tracy,
Thank you for providing the RouteThis code.
Based on the code, your phone is connected to 5GHz that is why the bulb keeps going offline. Please make sure you're connected to 2.4GHz.
Also, it shows here that you're using an ASUS/Netgear router. This router has a setting calle Airtime Fairness which limit the bandwidth of the devices on a network. We suggest you disable this setting.
They included a link to how to disable it but my router interface is completely different.
Thank you,
Tracy
