CyberTri
Apr 21, 2019Apprentice
Alexa not supported on RAX80??
Hey Netgear... Am I tripping or did you guys just release a brand new AX wifi6 device that doesn't support Alexas?! Did I just upgrade my X6 (supported) to an RAX80 to lose my Echo Spot and Echo s...
xjn
Apr 22, 2019Apprentice
I had the authentication error also and was able to fix it by removing network from Echo Spot and adding it back again and specifically selecting WPA2. I no longer see the error.
- Christian_RApr 24, 2019NETGEAR Employee Retired
Hello CyberTri,
I will forward this to the Engineering team and provide an update as soon as possible.
~Christian
- CyberTriApr 24, 2019ApprenticePlease do!!
- Christian_RApr 30, 2019NETGEAR Employee Retired
Hello Cybertri,
Thank you for your patience. The RAX80 supports Amazon Alexa devices and the landing page will be updated accordingly. If you're still experiencing issues, please send me a message with your contact info and I can ask support if they can reach out to you as soon as possible.
~Christian
