CyberTri
Apr 21, 2019Apprentice
Alexa not supported on RAX80??
Hey Netgear... Am I tripping or did you guys just release a brand new AX wifi6 device that doesn't support Alexas?! Did I just upgrade my X6 (supported) to an RAX80 to lose my Echo Spot and Echo s...
honndawg
Feb 05, 2020Aspirant
Is there any update on this Issue? Still on Firmware Version 1.0.1.70. Is there a time frame for a new firmware version release. I am so frustratued with not only my Alexa Show device connectivity issues, but also random connection drops throughout the week between cell phones and my smart hub. Didn't have this issues with my Asus Router. If nothing is done soon, I might just take it back and try a different brand of Wifi6 Router.
CyberTri
Feb 05, 2020Apprentice
Netgear replaced my RAX80 router and I still have the exact same issues. Recently I checked the 20/40 coexist setting. It seemed to stabilize the network for me over the past 2 days. Can you check if you have the setting enabled?
