CyberTri
Apr 21, 2019Apprentice
Alexa not supported on RAX80??
Hey Netgear... Am I tripping or did you guys just release a brand new AX wifi6 device that doesn't support Alexas?! Did I just upgrade my X6 (supported) to an RAX80 to lose my Echo Spot and Echo s...
CyberTri
Feb 16, 2020Apprentice
Hold up. Are we trying to say this is ok? Turn off UPnP and Samsung galaxy s10 Android devices also have auth issues.
Why doesn't Asus have the exact same issues? They have single SSID merging and you can turn off UPnP.
Hey Netgear, can I get a refund I would like to buy a router that works. You have decent distance, speed, AND external drive speed access is good. I even like your menu and access control features.
But your compatibility? FAIL
