Wayne1938
Jan 11, 2023Guide
All 5,GHz bands stopped broadcasting and are greyed out on my Nighthawk AX6600
Had no power problems and the unit is on a UPS, all of a sudden all three 5 GHz just disappeared. The 2.4 is the only band working. Go into the program and all 5GHz bands are greyed out. Any sugges...
michaelkenward
Jan 12, 2023Guru - Experienced User
Which Netgear model are we talking about here?
AX6600 is not a reliable guide to model number. Many devices come with an AX tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
Look at the label on the device for the model number. RAX70?
What does the 5 GHz LED look like?
Did you disable Smart Connect? When enabled you won't see separate SSIDs for 2.4 and 5 GHz.
