Wayne1938
Jan 11, 2023Guide
All 5,GHz bands stopped broadcasting and are greyed out on my Nighthawk AX6600
Had no power problems and the unit is on a UPS, all of a sudden all three 5 GHz just disappeared. The 2.4 is the only band working. Go into the program and all 5GHz bands are greyed out. Any sugges...
Wayne1938
Jan 12, 2023Guide
Thanks for your reply.
Nothing in the settings has been touched for at least 8 months. No updates have been installed.
This morning I did a factory reset and went through the process twice just in case.
When I get into the program and check wireless settings the only thing I could get into was the 2.4 settings. Both 5Ghz settings are greyed out.
Looking at the LEDs both the 5Gz are blinking as is the 2.4 LED.
The 2.4, is working fine so can only assume the 5.0 radios have died.
I installed an N600 WNDR3700v2 router I have had for years as a backup and it fires right up on both bands.
I will be using that temporarily until I figure out what I want to do or find a solution to what is going on with the AX6600.
The router is only 10 months old so will be calling Bestbuy to see what can be done.
Thank you
michaelkenward
Jan 13, 2023Guru - Experienced User
Is Smart Connect enabled?
We still don't know what Netgear router you are using. (The model isn't AX6600.) That makes it hard to be sure, but after a reset this will be enabled by default. When that happens you will not be able to control the Wi-Fi SSIDs separately. They are combined.
That could be why your 5 GHz is greyed out.
This is what the manual for the RAX70 says:
Note: If you enable Smart Connect and the SSID and passwords for the 2.4 GHz and
5 GHz bands do not match, the WiFi settings for 2.4 GHz band overwrites the WiFi
settings for 5 GHz band.
With Smart Connect you will not see separate WiFi bands.
How do you now that the 5GHz WiFi is dead?
To me it seems that your router is working perfectly. What you see is what I expect.
- Wayne1938Jan 13, 2023Guide
I ended up calling Netgear support before buying another router.
Found the 7-second paperclip push doesn't always work, the tech had me push it for a full minute. then turn it back on, that appears to have worked.
He took me through things I didn't know about, one being even though the Smart Connect wasn't checked he had me check it, rebooted the router then removed that check mark, as soon as I did the 5GHz bands appeared again and I could program the wireless. He had only seen that once before when someone was installing a Netgear wireless extender.
Well worth the Gearhead price. I learned a lot and now have support for a year.
The router is an AX8-AX6600-RAX 70-100NAS. That is all there is on the box other than the serial number and MAC address.
