travlr90
Jun 09, 2024Aspirant
All lights green on RAX35, devices can’t access internet
All lights show green on my Nighthawk RAX35 router. I’ve power cycled the modem and router and through the nighthawk app it says internet up/down is fast. I’ve also pressed the button on the back to d...
microchip8
Jun 09, 2024Master
There are no green lights on the RAX35. Only white and amber/red.
Did you cycle the devices in order?
Reboot modem and wait a few minutes to fully come up
Reboot the RAX35 and wait as well
Do you get Internet on wired devices?
Have you tried different DNS servers? 8.8.8.8 or 1.1.1.1 ?
Which ISP is your provider?
What is the modem model in front of the router?
travlr90
I turned off and unplugged and modem. Turned off the router. After 2 minutes plugged the modem back in and waited 2 minutes. Then I plugged in the router and waited 2 minutes.
