Scobleizer
Oct 25, 2019Aspirant
All sorts of connection problems with RAX80 and EAX80s
I'm having a ton of problems. Had this setup for about two weeks now, RAX80 hooked up to an AT&T fiber line and two EAX80s. When they work everything is amazing and fast. The problem is they almost a...
Outlaw0fTorn
Apr 06, 2020Aspirant
Im having the same problems with an RAX80 and EAX80.
I recently upgraded and have had nothign but problems with this. Cant even play World of Warcraft without my laptop dropping connection constantly.
billdavies
Apr 06, 2020Star
I seem to recall that I was to blame for some operator error. I added the extender via the Netgear app and assumed I was done. I think it was several days later I figured out that I actually had to login to the EAX80 and tell it to create a bridge to the RAX80, so all the app did was add the EAX80 to my WiFi network but did not configure the two devices to speak to one another.
- Outlaw0fTornApr 06, 2020AspirantThank you for responding.
I did log into the extender and got it set up but it just drop connection randomly causing my games to lag out still. Spent most of the day messing with it. Pretty much lost- Christian_RApr 08, 2020NETGEAR Employee Retired
Hello Outlaw0fTorn,
If you recently purchased your device please note that newly purchased devices are provided with 90 days of complimentary support from our support team. You may access your complimentary support using the link below. One thing to check is to see whether the device is connected to the extender or router during the connection drops/lag spikes.
https://www.netgear.com/support/default.aspx
Christian
