Scobleizer
Oct 25, 2019Aspirant
All sorts of connection problems with RAX80 and EAX80s
I'm having a ton of problems. Had this setup for about two weeks now, RAX80 hooked up to an AT&T fiber line and two EAX80s. When they work everything is amazing and fast. The problem is they almost a...
carys4
Apr 30, 2020Star
Having the same issues as many others who have paired the RAX80 and EAX80. I turned off the EAX80 for now and continuing to use the older tri-band X6S EX8000 as it is more robust and performs much better than the newer, more expensive EAX80.
