Scobleizer
Oct 25, 2019Aspirant
All sorts of connection problems with RAX80 and EAX80s
I'm having a ton of problems. Had this setup for about two weeks now, RAX80 hooked up to an AT&T fiber line and two EAX80s. When they work everything is amazing and fast. The problem is they almost a...
mikey2122
Jun 05, 2020Aspirant
I had nothing but problems streaming Netflix to some devices on the wired connection (even when I switched to wireless), also couldn't play PS Now (it would just spin in circles forever). All network and speed tests would show successful. I found someone suggest (to get PS now working again) change the MTU setting on the PS4 from 1500 to 1473. I did this and it started working again. I wondered if all this time, all the streaming issues I have had (even though I have 1Gbps download internet) was caused by the MTU setting in the router? So I went into the "Advanced", "Setup", "WAN Setup" and changed the MTU setting from 1500 to 1473 and saved the setting. Everything is working as intended now......no more network drops/lagging on any services.
