sun9wilson's avatar
sun9wilson
Follower
Sep 23, 2021
Already has wifi name and password
Hooked it up and it already has Wi-Fi name and a password. I can't get in and don't know what to do now. I just bought it I have never used it.
It's a netgear ax1800 Wi-Fi router..
Model# rax20
1 Reply
  • The factory WiFi password should be printed on the router's label on the underside of the router. If not, connect it with a cable to one LAN port, use a browser and go to http://routerlogin.net or http://192.168.1.1 and login with "admin" and "password". Then you can change whatever you like
