Eagle-Two's avatar
Eagle-Two
Apprentice
Aug 01, 2021
Android TV Ethernet connection issue
I have a RAX35v1 with firmware v1.0.3.94 and my Android OS TV over wired Ethernet is having issues connecting to the Internet. I have Access Control enabled and the TV shows as allowed. The TV can access the router but not the Internet. If I disable Access Control and then reboot the TV, it works. I can then re-enable Access Control in the router and the TV continues to have access to the Internet (even after rebooting the TV). Once the router is rebooted the TV can no longer access the Internet.
I have other devices that use wired Ethernet with the router and they don't have this issue. I haven't seen this issue after switching the TV to wireless. The TV software has already been updated.
Has anyone else experienced issues using wired Ethernet router connections with Android TVs?
