Lmerza
Nov 29, 2019Initiate
Another customer with rax80 issues
I just wanted to make sure netgear knows yet another customer is having issues with the rax80. All my google minis and ps4 randomly disconnect all the time. I'm trying to hold out here to hope they f...
Dec 01, 2019Guru - Experienced User
A little more info is needed.
1. What modem are you using? (model #)
2. What firmware is on the RAX?
3. Is it only the google mini's and ps4? are you using smart connect? If so try disabling it. Maybe its an issue with how they respond to smart connect.
4. Have you factory reset the RAX recently? The firmware updates they've been getting have been substantial as its a pretty new device. They've responded favorably to factory resets after significant firmware changes.
- LmerzaDec 05, 2019Initiate
No it's everything on the network.
Firmware Version V1.0.1.64_1.0.27
spectrum modem E31U2V1
disabled smart connect and reset after firmware upgrade.
still problems almost daily.
