jguerdat
Jan 09, 2026Guru
another OpenVPN issue
Guess it's from a recent app update on both Android and W11. The connection attempt fails every time. The only warnings/errors I see are: Fri Jan 9 16:10:22 2026 WARNING: No server certificate v...
- Jan 11, 2026
Well, hell's bells. I figgered it out. I have the DUC utility on my laptop to keep my No-IP address up to date. Of course, I'm not home so it's updating based on my current connection, not my home router.
Talk about a headset short. Thanks for the attempts to help. Crap...
Jan 09, 2026Guru - Experienced User
Was this working up to this point and didn't after the Android and W11 update? If so, then maybe something on there side would need to be looked at.
Might get ahold of OpenVPN as well and see if there maybe any new known issues on there side.
What NG product are you using?
jguerdat
Jan 09, 2026Guru
The W11 issue is new since it's a new computer replacing my old W10 one. I'm away from home so can't check that but I'll wager it's on all platforms. I'm using an RAXE300 router. Again, since I'm not at home, I can't download the profile again to see if NG changed something to allow it to work.
