jguerdat
Jan 09, 2026Guru
another OpenVPN issue
Guess it's from a recent app update on both Android and W11. The connection attempt fails every time. The only warnings/errors I see are: Fri Jan 9 16:10:22 2026 WARNING: No server certificate v...
- Jan 11, 2026
Well, hell's bells. I figgered it out. I have the DUC utility on my laptop to keep my No-IP address up to date. Of course, I'm not home so it's updating based on my current connection, not my home router.
Talk about a headset short. Thanks for the attempts to help. Crap...
CrimpOn
Jan 09, 2026Guru - Experienced User
What OpenVPN Client is being used on Windows 11?
- StephenBJan 10, 2026Guru - Experienced User
jguerdat - version 2.6.12 is working on my Win 11 PC, I am also using TUN on port 12973. The GUI is 11.50.0.0.
Though I have an Orbi 870 system, so we are using different routers.
- jguerdatJan 10, 2026Guru
The GUI, which was freshly installed as part of the package, is 11.59.0.0. I doubt that's the issue due to the phone also not working.
2.6.17-I001-AMD64
jguerdat wrote:
2.6.17-I001-AMD64
I'll see if I can test that and report back.
StephenB wrote:
2.6.17-I001-AMD64
I'll see if I can test that and report back.2.6.17 works for me with my Orbi 870. This was also a clean install (using a PC that never had OpenVPN installed).
I am wondering if something happened to disrupt your service at home.
