jguerdat
Jan 09, 2026Guru
another OpenVPN issue
Guess it's from a recent app update on both Android and W11. The connection attempt fails every time. The only warnings/errors I see are: Fri Jan 9 16:10:22 2026 WARNING: No server certificate v...
- Jan 11, 2026
Well, hell's bells. I figgered it out. I have the DUC utility on my laptop to keep my No-IP address up to date. Of course, I'm not home so it's updating based on my current connection, not my home router.
Talk about a headset short. Thanks for the attempts to help. Crap...
jguerdat
Jan 10, 2026Guru
2.6.17-I001-AMD64
Jan 10, 2026Guru - Experienced User
jguerdat wrote:2.6.17-I001-AMD64
I'll see if I can test that and report back.
- StephenBJan 10, 2026Guru - Experienced User
StephenB wrote:
2.6.17-I001-AMD64
I'll see if I can test that and report back.2.6.17 works for me with my Orbi 870. This was also a clean install (using a PC that never had OpenVPN installed).
I am wondering if something happened to disrupt your service at home.
