jguerdat
Jan 09, 2026Guru
another OpenVPN issue
Guess it's from a recent app update on both Android and W11. The connection attempt fails every time. The only warnings/errors I see are: Fri Jan 9 16:10:22 2026 WARNING: No server certificate v...
- Jan 11, 2026
Well, hell's bells. I figgered it out. I have the DUC utility on my laptop to keep my No-IP address up to date. Of course, I'm not home so it's updating based on my current connection, not my home router.
Talk about a headset short. Thanks for the attempts to help. Crap...
Jan 10, 2026Guru - Experienced User
jguerdat wrote:It recently worked although I don't recall exactly how recently - Prolly a couple/few months ago. Anyone got clues?
If your router is set up to respond to ping requests on the WAN interface, then you might want to try pinging your ddns name. If you use Netgear's service, then maybe go back and see if you forgot to re-up the service when you got a monthly email reminder.
