jguerdat
Jan 09, 2026Guru
another OpenVPN issue
Guess it's from a recent app update on both Android and W11. The connection attempt fails every time. The only warnings/errors I see are: Fri Jan 9 16:10:22 2026 WARNING: No server certificate v...
- Jan 11, 2026
Well, hell's bells. I figgered it out. I have the DUC utility on my laptop to keep my No-IP address up to date. Of course, I'm not home so it's updating based on my current connection, not my home router.
Talk about a headset short. Thanks for the attempts to help. Crap...
CrimpOn
Jan 10, 2026Guru - Experienced User
It might be worth the effort to download the Windows configuration file from the router and use it rather than the smartphone configuration file.
Also, the Windows setup instructions are pretty clear about renaming the network adapter.
jguerdat wrote:trying to use the smartphone .ovpn on W11 which worked fine in the past on W10
An interesting concept. I have always blindly followed the instructions, i.e. use the smartphone configuration/instructions for phone/tablet, use the Winidows configuration/instructions for Windows.
I have set the debug level to produce more information in the log, i.e. change verb 0 to verb 5
