mtb640
Aug 29, 2020Aspirant
antenna installation on AX4300
The manual for the AX4300 that I bought at Costco states, "Make sure to match the labels on the antennas with the labels on the router. The antennas must be attached to the correct antenna post on t...
mtb640
Aug 30, 2020Aspirant
Thanks for the reply. Definitely no labels on either the router nor the antennas. It appears to be working (although I had some issues while setting it up - the 2.4 band didn't work, but the 5.0 band did. It somehow resolved itself and now both are working). I put a support ticket in to see if it matters which antenna goes where on the router.
dsted
Sep 17, 2020Aspirant
I just purchased the AX4300 ( Model RAX45) from Costco and none of the antenna or router was labelled. There should have been labels stating "Rear" or "Side". Is there a sequence or order to screw in the antennas ( 4)? How can you tell them apart, they look the same
- CallPaulSep 17, 2020Apprentice
- I took a look at mine and they're marked rear and side on the base of the antenna where it screws into the router
