mtb640
Aug 29, 2020Aspirant
antenna installation on AX4300
The manual for the AX4300 that I bought at Costco states, "Make sure to match the labels on the antennas with the labels on the router. The antennas must be attached to the correct antenna post on t...
SteveGH
Jan 02, 2021Aspirant
I bought this same router recently and there are no lables anywhere. Of course, it won't update to the latest firmware either so I may end up taking it back.
- CallPaulJan 02, 2021Apprentice
They did away with the labels and you can install any of the antennas in any port.
I got rid of it a long time ago, wasn't a very good router at all. I'm done with Netgear.
SteveGH wrote:I bought this same router recently and there are no lables anywhere. Of course, it won't update to the latest firmware either so I may end up taking it back.
