sanketprajwal
Dec 07, 2022Initiate
Antenna Part Number: NETGEAR RAXE500
Hi , I am trying to get the Part Number for Antenna Pigtail - SMA Connector to Rewire the Antennas of RAXE500. It would be helpful if I could get the part number. Please let me know. Thanks...
Dec 07, 2022Guru - Experienced User
You can try checking on the fcc site to see if they're stock units or not for the part you're looking for.
https://fcc.report/FCC-ID/PY320300508/5205951
sanketprajwal
Thanks for the Info. However, I couldn't find the exact Part Number for the Antenna Pigtail from the Documents
- plemansDec 08, 2022Guru - Experienced User
I don't think you will. Netgear doesn't even sell replacement antenna's for the routers with detachable antenna's so I highly doubt you'll find them for the ones integrated into the wings on the raxe.
