sanketprajwal
Dec 07, 2022Initiate
Antenna Part Number: NETGEAR RAXE500
Hi , I am trying to get the Part Number for Antenna Pigtail - SMA Connector to Rewire the Antennas of RAXE500. It would be helpful if I could get the part number. Please let me know. Thanks...
sanketprajwal
Thanks for the Info. However, I couldn't find the exact Part Number for the Antenna Pigtail from the Documents
Dec 08, 2022Guru - Experienced User
I don't think you will. Netgear doesn't even sell replacement antenna's for the routers with detachable antenna's so I highly doubt you'll find them for the ones integrated into the wings on the raxe.
