rplatham
Oct 16, 2025Follower
Any clue if 1.1.6.36 fixes the login issues in 1.1.4.28
FURRYe38 any clue if 1.1.6.36 fixes the login issues in 1.1.4.28 that were "solved" by downgrading to 1.1.3.18? Yes, I've been waiting too... https://community.netgear.com/discussions/en-home-routers-nighthawk-wifi-ax6/netgear-nighthawk-rax50v2---access-denied-bug-solved-solution/2421916
1 Reply
I believe so. I'd not seen this issue with v.28 loaded and after doing a full on factory reset on the router. Normal web ui log in is maintained. Something to try and see.
