michail71
Jul 22, 2020Apprentice
Any way to see a list of RSSI Levels?
Is there a way to view RSSI levels of all connected devices? I think ever AP I've had in this century has had this but I can't find anything other than a graphic on the phone app.
RajaDaja
Jul 25, 2020Luminary
Easy if youy got a Apple Mac computer, do you?
michail71
Jul 25, 2020Apprentice
No, is there an app that can pull them from the router? I figure they must be there somewhere since the phone app shows a graphic.
- avtellaJul 25, 2020Prodigy
You don't specifically need a Mac, plenty of apps on Windows and Android as well. inSSIDer is a very poplular one (has a free version) and many more. Acrylic WiFi is another as well.
Yeah I wish the router had it in its Web GUI unfortuantely NGs routers are kinda watered down in the featue side, so you are out of luck there.
The MacOS built in one is flakey at times when it comes to updating RSSI data, so I use WiFi Explorer to get more realtime info.
