Romaniuc
Dec 13, 2023Tutor
Apple and Wi-Fi 6E
After upgrading the RAXE500 firmware to V1.2.13.100_2.0.54 and iOS to 17.2 for the iPhone 15 pro max and iPad Pro 6Gen 12"...... The connectivity issues remain đ I deactivated the Smart Connect fe...
Dec 13, 2023Guru - Experienced User
What connectivity issues are you seeing? Please explain?
What issues are you seeing with Smart Connect enabled and disabled?
What channel configurations are currently set on the router?
Does this only happen with Apple devices?
What other devices are connected to the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
Romaniuc
Dec 13, 2023Tutor
When Smart Connect is enabled, the Wi-Fi connection on my Apple devices iPhone 15 Pro and iPad Pro 6Gen 12" having connection dropping. I supposed that something related to the Wi-Fi 6E band.
Disabling the Smart Connect, I'm able to segregate the 3 bands of Wi-Fi and I could select which network my device will connect. Even in this situation, the speed barely crosses 60MB. This only happens in the iPhones 15 Pro and iPad Pro 6Gen.
I have an Apple Macbook Pro 14 M2 Max (Wi-Fi 6E) and there is no issue. The speeds on the MacBook are faster than 650MB.
Let me know if these infos helps in understanding.
Appreciate.
- FURRYe38Dec 13, 2023Guru - Experienced User
Since Smart Connect doesn't include 6Ghz nor is 6Ghz with in the main WLAN or combined with 2.4 and 5Ghz network, You can leave SC enabled.
I'd try a lower channel on 5Ghz, say 40 or 48. Then try channel 149 to 161. Try different channels on 6Ghz. Say lower channels. I've always used 69 and has worked for me but I don't have a iPhone 15. 12 Pro Max and still at iOS16.5.
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-messageI've heard also thru the grape vine that there is known issues with the wifi on iOS17 and Apple and NG seem to be already aware of that. So you may need to wait for next iOS update in hopes to check this. Would be somewhat validated by your Mac Book Pro not having issues when your iPhone is.
- schumakuDec 14, 2023Guru - Experienced User
The crux with 6E is that 6 GHz does mandatory have WPA3 (Personal/SAE or Enterprise) - so using a common WiFi carpet on all three bands is kind of prohibiting, because all your nice toys and printers or popular IoT won't work on WPA3 -or- the smart-a** device makers start to issue warnings in case there are similar or same(?) SSIDs on all three bands, where some are configured for WPA3-(any) and WPA2-(any), even if the SSID has a post-fix like -5g or -6g 8-)
