vlxiim
Feb 28, 2020Tutor
Apple TV and iOS products not staying connected.
My set up: RAX120 with 2 EX8000's 6 Apple TV's, 9 Apple iOS Devices. 5 AV recivers, Smart TV's 8 PC's, 3 Printer's 6 Amazon echo devices Ring and security cameras Dozens of lighting and c...
michaelkenward
Feb 29, 2020Guru - Experienced User
It might help if you told people what the modem is in front of this router. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router.
Having two routers on a network can cause headaches. The symptoms you see could be down to this. We won't know without more details.
- vlxiimMar 02, 2020Tutor
I don't have the part # but it is just a modem. It does not do DHCP severing. As I said This has been running on an Apple Air Port network for years with no problems.
- ClibertMar 08, 2020StarI was having issues with a cm1000 which is not a router just a modem and a Netgear one at that. Sounds like the issues I was having
- michaelkenwardMar 08, 2020Guru - Experienced User
Clibert wrote:
I was having issues with a cm1000 which is not a router just a modem and a Netgear one at that. Sounds like the issues I was havingUnlikely.
An Apple TV, or any other device, cannot connect to an CM1000 unless it is wired to the LAN port. That would rule out using the modem for anything else.
I see no sign in the manual that the CM1000 can act as a router.
